I use Virtualdub to join avi's no probs but am looking for some software where I can view the clips side by side and perform cut/snip to get rid of some bits before joining them. Looking for something that won't re-encode the clips either.
I use Virtualdub
try virtualdub
Lol?
doh, errm,
Other programs re-encode as opposed to "direct stream copy"...doh, errm,
Virtualdub can do everything you mentioned, so try it again!Other programs re-encode as opposed to "direct stream copy"...
You need to cut on the keyframes if you can, and you can also make selections and delete parts of the clip before processing...The problem with Virtualdub is that I can't get the 2 clips on the screen at the same time which makes it very difficult to cut out the overlap, or am I doing something wrong?
