Software to edit avi's
3 Apr 2007
South of the Watford Gap!
I use Virtualdub to join avi's no probs but am looking for some software where I can view the clips side by side and perform cut/snip to get rid of some bits before joining them. Looking for something that won't re-encode the clips either.
:o doh, errm,
Virtualdub can do everything you mentioned, so try it again! :p Other programs re-encode as opposed to "direct stream copy"...
The problem with Virtualdub is that I can't get the 2 clips on the screen at the same time which makes it very difficult to cut out the overlap, or am I doing something wrong?
You need to cut on the keyframes if you can, and you can also make selections and delete parts of the clip before processing...
I don't know how to get 2 clips on the screen at the same time tho...
Thanks guys, MikeHunt79 mentioning keyframes did it for me, used Virtualdub and cut and joined at keyframes and all is fine :)
EDIT: No idea why I never tried but you can have 2 or more copies of Virtualdub running so was quite easy to do in the end.
