Hey rjkoneill,today i have been busy giving my chip a thrashing
after the untimley demise of my p6t deluxe [RIP] and with it my old 920 and memory
I'm not sure if I'm reading this right but are you saying you toasted a £500 of hardware?
also - futuremark ORB system seems to pick my chip up as a 975 when its overclocked past 4.5GHz
hope they fix this
Doubt it as most boards would be limited to around 222mhz bclk if you're lucky (although I've seen 230 on a DFI) with a max multi of 21x. That would only give you about 4.6ghz. I would have thought that what Rjkoneill got is pretty much the maximum you can get on an i7 920.
How come my p6t deluxe says I can raise it to 500bclk?
Hey rjkoneill,
I'm not sure if I'm reading this right but are you saying you toasted a £500 of hardware?![]()
It's the base clock i.e the core i7 equivalent to the fsb.
managed to get a 4GHz profile stable at 1.18v![]()
Coolmy D0 arrives tommorow
But after failing to overclock my C0 could you please tell me what you changed the qpi voltage to? (I think its called that, its the other voltage that needs to be changed with cpu volt but I'm not sure of the name)
I have a p6t deluxe btw so does that mean bios settings have a different name?
That's brilliant man! What load temps are you getting with that profile?
i used to have that board - its fairly easy
what cooler are you using?
if you have a D0 stepping CPU it'll be simple.
Mine is running @ 1.296v @ 4.2ghz
not tried for more as i already feel this is a massive clock from stock 2.66ghz
