Internet connection lost - bt socket?
7 Feb 2004
Looks like the main socket connector or wiring has gone on it. How do I repair this?
If I plug directly into the main socket it works ok, but when I place the outside panel on it doesnt.
Do I need to get a professional in or can I just buy a front panel and do it myself? If so are there any that are recommended that would provide a better connection?
Thanks
BT NTE5 Master socket
is what i think you are after,google it as a lot of links may be to competitors i can`t link
Should be a case of just plugging in a new faceplate if the test socket is working :)
I thought only BT could work on your master socket?
Only BT can (legally) work on your master socket, as in the bit that actually attaches to the wall. You can pretty much do whatever you want with the faceplate.
This seems like a pretty good resource after a quick googley search for this, which you should try to buy if you're replacing the faceplate as it does pretty much the same job as an i-plate and eliminates the need for microfilters.
Yeah its only the face plate that I need replacing. I wouldnt take off the actual thing from the wall.
