Windows 7 hits RC stage Build 7100
The one I have is this size
Oh goody! I didn't realise you could still get the labels back on the Taskbar buttons when the programs are running. Much better. I used to keep hitting wrong icons and then have to wait until the program launched when I meant to just switch back to an active window.
it's still illegal, since it's not officially out
and I don't think that all the members of this thread are OEM companies
Well 7100 was a painless upgrade.
Granted, I had very little installed as 7068 was a fresh install but it seems to be a little faster, streaming to the xbox360 has been fixed and an update has been released for the 360 regarding Windows 7.
About to install it on my NC10 netbook now.
Edit: Flawless install on the NC10. Installed quickly via a usb stick. Just need to setup the power management lark now.
Hmm, I have 7100.0.090421-1700_x86fre_client_en-us_Retail_Ultimate-GRC1CULFRER_EN_DVD.iso
But went to install on my virtual machine and my AV has told me there is spyware/trojans. Namedly codecic.exe and codec_v1.1.exe. During the installation..
Not liking this..
Not liking this..
Think you might have got a dodgy copy there mate, Can't find those files on the .ISO I downloaded.
Its one of the most popular ones too.. no one will notice the trojans if they do a normal install. The file size was 2.37 too, and the current one im getting is 2.35.. so me thinks someone added a little spice to that one..
Win32/Injector.HP Trojan usually found in those executables.
Unless you can absolutely verify a non tampered build I have no idea why anyone would even consider using dodgy torrents.
Very odd.
I got mine from newsgroups
2.34 GiB (2,508,564,681 bytes) is the full size of mine but 32bit not 64bit :)
