you are forgiven*shakes hand*
You see i can see your point about using it for Aperture...
Ok here is a question. on your unibody. Would you notice a difference in photoshop tasks compared to pc's you have used in the past etc?
I hate Adobe with a passion! Bunch of lazy so and so's! They haven't bothered to do a 64bit version of a Photoshop on mac yet which really annoys me!
I'd say if all you use is photoshop then a PC would be the way to go. Adobe put a load more effort into their windows software!
Aperture and Logic Studio 8 are great programs and are only on a Mac. I never used Photoshop extensively on a PC so i can't really compare against it, it really is the same program and at the moment windows has the upper hand with a proper 64bit version ala CS4.
When snow leopard comes around though the story will change, adobe will be forced to code 64bit and hopefully use OpenCL which will speed it up considerably!
EDIT - In the O.P you say you have an "Old" 2.5GHz 17". I have a 17" 2.33GHz and it is still a very capable laptop! I have still got it! I could still sell it for near enough a grand and that a 2 and a half year old laptop! Compare that to a PC laptop for example. I also have a PowerMac Dual G5 which i can sell for £500, that's nearly 6 years old!
