You would since you'd not need to defrag an SSD and thus won't get a drop in performance as a SSD fills up with randomly spread out, fragmented data!
This cable seems very high quality, build quality wise of course so it’s not likely to be replaced any time soon unless I have to move house or something, I will never have the speakers further apart than 2 metres max anyway on this system as it’s used for the PC only.
I think the price is ok, it’s not mega expensive that’s for sure, I’ve seen cables that are close to £500 and even higher! The XT is also classed as a budget cable... I draw the line @ above £50 for a set of cables tbh!
Likewise gaming mice, I had the new Mamba from Razer, not worth £120 for what you're getting.
