Jonny69's inventing shed: Giant Spudmatic gun
Man of Honour
Man of Honour
3 May 2004
Kapitalist Republik of Surrey
Jonny69's inventing shed: Giant Spudmatic gun (video added)
On another forum I'm being pestered to put some more of my toys online so I'm going to run a series of threads and show you what I've got in my garage. I'll start with the spudmatic gun I made today and move onto some of the older stuff as my bandwidth allows :D
So, plan is to make a little reservoir out of steel tube that I can pump up with a bike pump and have a ball valve at the other end to let it all out at once. No fire, reliable and repeatable tried and tested method which I used last week on one of the gags at work, for firing a model Polaris missile.
Start with a bit of 75mm tube, this bit is 250mm long:
It needs two endcaps, one with a hole in it. Cut these out with a 1mm blade in the angle grinder, then clean them up with a flap wheel. The hole is cut with a Screwfix holesaw which has lasted just 3 holes in 2mm steel:
(I'm not all pro using engineers blue but the way, the steel I had happened to have it on already)
Through that hole is going a brass tank fitting, a common plumbing fitting for 15mm copper pipe:
Fits through the hole like so:
I've drilled a hole in the side so I can squish through a tyre valve that I got from the local tyre place:
This is the only difficult bit for most people, welding the ends on:
The tank fitting needs to be tightened up before the end is welded on so I cranked it up paggin' tight with some PTFE inside, welded in short stitches and cooled in water each time to stop too much heat getting to the brass:
It's assembled with a lever ball valve tap thing, again, another common plumbing part with compression fittings so no tapping or soldering needed:
And this is how it works, fairly self explanatory:
Testing.
The good news is it works pretty well. The pump is a bit rubbish but 40psi sends a 15mm slug of potato clean over the 3 stories of flats in my building. 100psi sends it right over the block adjacent and 160psi which is pretty much all I can manage with all my weight on the pump goes about 75 metres down the road with a bit of recoil.
I'm chuffed, first toy for the camping trip in June is complete. Better stock up on potatoes :D
Edit: video is in post 36 :)
Edit 2: more silly video in post 68 :D
If you fit a second tap, with say 250mm of pipe between the 2, you could get multiple shots without pressurising the whole tank again.
That air would want to become over 2500mm long quite quickly, ample for your length of barrel I think.
That looks pretty amazing - 75m?! Crazy!
You should build a few and experiment with longer barrels or pressure chambers. I'd like to see a proper compresser being attached to that!:cool:
The "big one" we built at work for launching large objects is a 6ft nitrogen bottle with a 4" ball valve welded in the top. That goes through a flexi hose rated at 10,000psi to a 4" diameter 10mm thick steel nozzle, about 2 metres long. This all sits in a steel cage about 4 metres long. We'd fill it up to about 1750-2000psi using multiple bottles of nitrogen and fire a steel platform off it with all sorts of stuff loaded on top. You might have seen it in the Richard Hammond Engineering Connections series when they shot a steel sleeve off the end and it went several hundred metres. I wasn't on that shoot unfortunately but it was the same cannon ;)
The reason I used the tyre valve is because I can put the car tyre compressor on it and pump it up to 260psi. Never worked out why they go that high but I've got a use for it :D
Nice build Jonny :D
I've got a 'tato gun I made at work from uPVC, 3" Combustion chamber with 1" Barrel (used to be 1 1/2" Barrel) Fires them pretty darn far with either Ether or Hair spray as a propellant.
