Love this. However, the font in the 'OcUK' versions of the logo doesn't quite sit right. Not sure what it is so can't really suggest a 'fix' - perhaps you could play with it.
I think the top logo is spot on - certainly my favourite. Well done.![]()
Software most probably used, which i used aswell.
Adobe Illustrator, look up some tutorials it all paths and shapes so it takes a while to get into.
Dangerstat - would love to - tend to jump around fairly erratically. as robot robot said, Illustrator is the juggernaut for this sort of thing, photoshop gives a little more flexibility for sit testing (ie what does it look like in x,y,z location). Also use a variety of other cool apps which each have their own particular strengths (eg Xara Xtreme Pro is very much worth a look - knocks chunks off illustrator for freehand design). But most of all the majority is done off screen - sketches, brainstorming business drivers and creative thoughts.
For the tech stuff, highly, highly recommend a wacom tablet...
TriedandTested - Agree, actually think it's the kerning would benefit from a tiny, tiny tweak - actually changed a later version, but don't want to keep submitting final, final entries etc.
int -As you're a bristolian too, I'll take your damning! Spent many a year in Redland and up at Clifton!![]()
Thanks for the relies, I have a bitter hatred of Adobe products for the outrageous pricing policies - is there any GNU software that is remotely as good as illustrator
Nice work Naster.
What do you do?
I will split GTX for two of us
ok, trying to kill two birds - have sketched a forum version as Skippi asked and have designed as a seasonal variation (halloween) to demonstrate the potential ways to tailor as mentioned to Naster - keeping the brand sharp and doing its job while livening up around it...
Have also kept it as same theme as present (would again suggest maybe a reskin of the forums to fresh things - white's nice, but this shows the art of the possible right now)
That's awesome. A couple of those pre-made for different seasonal events would be great.
I say Spie should send you a custom PC.![]()
