- 23 Mar 2009
- Peterborough
I'm not buying this for another couple weeks when my exams are over as i'd never get any revision done with new toys. This however gives me time to decide on what to buy. So the question is should i change anything here? I have a budget of £350 to spend on parts so if you feel i might benefit from something else feel free to add it.
My spec is
Intel Q6600
4Gb of elpida DDR2 (800Mhz)
Antec Earthwatts 650W
Sapphire 4850 (512mb)
500Gb Seagate HDD
Cheap Dell mobo (hence the new one)
2x Dell 20" monitors
CM 690 Case
A few questions also:
If i was to ditch the new RAM would the elpida stuff still work in the new motherboard ive checked for compatability charts and stuff but they all seem to be rather unhelpful and state that other RAM might work.
I'm considering getting some new quieter fans to put in my case does anybody have any reccommendations? or should i go for a fan controller and dial the current ones down when i need it quieter?
