My TJ07
25 Nov 2007
Suffolk
Not a new build but after being built for a while and now been to a couple of lans it needed abit of tidying up. I also got rid of my rear UV/LED fans for the standard Silverstone items and took most things to bits for a decent air dusting!
Looking to go Core i7 early next year if all goes to plan, but for the time being the spec is:
Motherboard: Asus Maximus Extreme
OS: Windows XP Pro SP3
PSU: 800w Tagan TG-800-U33 2ForceII
CPU: Intel Core 2 Duo E8600 E0 3.3Ghz @ 4.5Ghz
Memory: 2046MB OCZ Platinum DDR3 PC3-14400
Hard Drive 1: Seagate 500Gb 7200RPM 32MB Cache
Hard Drive 2: Seagate 500Gb 7200RPM 32MB Cache
Hard Drive 3: Seagate 320Gb 7200RPM 16MB Cache
Video Card: 512MB MSI 8800 GTS OC @ 855/2025/1100
Sound Card: Sound Blaster Audigy 2 ZS
Case: Silverstone TJ07B-W
Rad: ThermoChill PA120.3
CPU Block: D-TEK FuZion + Nozzle Pack
GPU Block: EK-FC88GT 8800GT/GTS G92
Pump: Swiftech MCP655-B
Tubing: Masterkleer 7/16" ID 5/8" OD PVC
Res: XSPC 5 1/4 Bay Reservoir
3DMark06: 17765
Nothing amazing compared to some of the mods and spec of some of the machines on here, but never the less:
Dan :D
my p190 is bloody heavy as well.
what does that lcd poster actually do ?
ive got one but never saw the point of putting it in tbh.
No chipset cooling :o lol
Very nice one the less :P
lol, was my first WC build so just went for CPU & GPU this time. Core i7 time ill go the whole hog, the chipset temps are fine at present. No point in using the default Asus WC blocks though, totally useless!
and where about's in ipswich are you ?
im in ip4
Just outside Ipswich in Woodbridge :) A local watercooling guy! :D
just down the road to me....i work at martlesham tesco.
