Took the plunge and bought it, if only i could get the missus of it to have a go
Had that startup error again, apparently it happens if you have a Asus Xonar soundcard. To get it to work you need to close steam down, then restart it but 'run as admin', been a while since ive had a prob in vista with gaming
Run as admin doesn't seem to be working for me, what exactly was it you did to get it going?
Just bought it
That's my weekend sorted.. two new Tower Defense games to get through![]()
Whats surprising is just how much of the lyrics I can remember after just one listen![]()
Is it me or is this reaaaally easy? with no scaling to the zombies the only difficulty seems to be in building up which is also very simple and done in the exact same way each time, so after 5 minutes if you're still going you've won
Does it get much harder? (on stage 5-x atm)
YEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
