12 May 2009 at 14:09 #1 PiKe PiKe Caporegime Joined 18 Oct 2002 Posts 25,295 Location Lake District Can anyone recommend any software that will read bar codes from the DVD's and then add them in to a virtual library to make searching for them easier?
12 May 2009 at 15:20 #2 SourChipmunk SourChipmunk Soldato Joined 9 Nov 2003 Posts 9,516 Location The Motor City Find yourself a CueCat scanner from the Bay (was originally meant for books, iirc). DVD software here: http://www.bolidesoft.com/barcode.html
12 May 2009 at 15:22 #3 PiKe PiKe Caporegime OP Joined 18 Oct 2002 Posts 25,295 Location Lake District Just found one called MediaMan that supports barcode scanning from webcam.
12 May 2009 at 15:51 #4 SourChipmunk SourChipmunk Soldato Joined 9 Nov 2003 Posts 9,516 Location The Motor City PiKe said: Just found one called MediaMan that supports barcode scanning from webcam. Click to expand... That looks pretty nice. Can you keep us updated on how well it works?
12 May 2009 at 16:00 #5 dan^uk dan^uk Associate Joined 2 Jun 2003 Posts 358 I use DVD Profiler: http://www.invelos.com/
12 May 2009 at 16:08 #6 Tomsk Tomsk Soldato Joined 18 Oct 2002 Posts 5,237 Location Overground, underground.. I use Movie (and Music and Book) Collector from www.collectorz.com
12 May 2009 at 16:21 #7 LostCorpse LostCorpse Soldato Joined 14 Jun 2004 Posts 8,263 This probably wont be helpfull but might be of some limited use.. http://sourceforge.net/projects/vvvapp/
