- Ok so ive gone from HD3870 crossfire to 4890 crossfire >installed drivers from website
10 minutes of FSX > loads of artifacts, PC locked up a minute later.
manually rebooted
- Clicked on 3D Vantage > the window was white..as if trying to detect hardware, then locked up after 2 minutes of hour glass.
manually rebooted
clicked on a different 3d Benchamark, artifacts wthin seconds and unit locked up.
manually rebooted
POST > black screen with cursor> 40 seconds still black with windows cursor> Vista Splash screen > logs in > wallpaper looks like 16bit colour (not as bad but very similar 'look')> then small green boxes begin to appear little by little untill you can hardly see desktop > unit freezes/locks up.
- Safemode > totall fine
stripped my COMODO filewall from MSCONFIG
- Loaded into Windows but same
took out one of the 4890 cards > no change
- Swap test with other card > no change
had work so stopped at that point.
each card has TWO 6 pin PCI-E power connectors (wow!).
I have a 700W 5 year old PSU but no issues with my 2x3870 so....
Q9550 @ 3.6
4x1066RAM
manually rebooted
manually rebooted
manually rebooted
Q9550 @ 3.6
4x1066RAM
