With that app can you have custom ringtones for different people?
yes
You love your Android phone? You SMS all the time? Then chompSMS is for you: It's got a great user interface, chat style SMS bubbles, touchscreen keyboards and many other great features! Also coming soon, T9 predictive touchscreen keyboard and color customizations.
Upcoming New Features
- Ability to flag all Messages as "Read".
- Add support for custom Font Packs.
- Delivery Reports
- Ability to quickly pick multiple contacts.
Excellent stuff. Might pop into town and have a play with one I think![]()
It comes with a case![]()
As i'm within the 14 day cooling off period i might have a go at blagging vodafone to change me to the magic on the basis that i don't like the 5800. Is it worth a try?
Definately, if your within the 14 days you can demand a better handset (as yours were poor) or threaten to cancel the contract.
The other guys in this thread are better poised to answer the magic's build quality.
Thanks for the response. Do you think it's worth it over the 5800?
One more quick question...........the headset, I like to listen to tunes on my mobile, is the headset bulky and how good does it sound?
I had the 5800 and the HTC is miles better in terms of build quality. The screen itself doesn't feel plastic and thin and doesn't flex like the Nokia one did.
It does not feel cheap at all, as I mentioned before, it feels like a one piece unit and feels tough although I'm not going to test it to it's limits anytime soon
The pouch it comes with is fine, it's soft and padded inside so will protect it nicely, it's leathery too and has stitched edging but the opening remains open so if you drop it and it falls that side first then there may be problems....
I use it as a mattress when I put the phone on the table at work for example, stops the back from scratching
The headset is poo quality, as with most bundled headsets. Best buying a 3.5mm adapter for £1 on ebay then using your own headphones.
The music player works nicely too, does anyone know if there's a special way to put music on the sd card too like you do with ringtones and stuff?
