- 27 Jul 2005
- The Orion Spur
Well, here it is lady's and gentlemen,
The PS3 Slim
RRP £249
The Spec's
Product Code: CECH-2000 (Charcoal Black)
CPU: Cell Broadband Engine
GPU: RSX
Audio output: 7.1CH LPCM, Dolby Digital, Dolby Digital Plus, Dolby TrueHD, DTS, DTS-HD, AAC.
Memory: 256MB XDR Main RAM, 256MB GDDR3 VRAM
Hard Drive: 120GB Serial ATA
Inputs / outputs:
Hi-Speed USB (USB 2.0): 2
Network: Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T) x 1, IEEE 802.11 b / g, Bluetooth 2.0 (EDR)
Controller: Wireless controller (Bluetooth)
AV output HDMI OUT Connection: 1
AV output AV MULTI OUT connector: 1
AV output Digital out (optical) Connection: 1
BD / DVD / CD drive (read only) Maximum read rate: BD × 2 (BD-ROM), DVD × 8 (DVD-ROM), CD × 24 (CD-ROM)
Power Consumption: Approx 250W
Dimensions: approx 290 × 65 × 290 mm (width × height × length)
Weight: approx 3.2kg
And here it is in the flesh,
CLICK ME - A good gallery of photos showing the PS3 Slim compared to consoles past and present - CLICK ME
Videos,
Additional information,
The HDD on the PS3 Slim is accessible via the front panel like so,
Peak power usage :
Launch (90nm Cell / 90nm RSX) was 200W
40GB (65nm Cell/ 90nm RSX) was 160W
80GB (65nm Cell / 65nm RSX) was 130W
The PS3 Slim (45nm Cell / 65nm RSX) peak power usage is estimated @ around 74w
And for the audio enthusiasts,
http://www.engadget.com/2009/08/21/ps3-slim-bitsreams-dolby-truehd-and-dts-hd-ma-audio-at-last/
And Finally some speculation,
Sony's PS3 Slim Carries Updated Cell Chip
"Sony has made some enhancements under the hood to boost its processing speed and power efficiency. The gaming console will carry an upgraded version of the Cell microprocessor, which is being jointly developed by IBM, Sony, and Toshiba."
"IBM spokesman said. Based on IBM's Power architecture, the chip delivers many performance improvements while drawing less power than earlier chips, IBM has said. The earlier console carried a Cell processor manufactured using the 65-nm process. IBM declined to provide the clock speed of the new Cell processor."
The PS3 Slim
RRP £249
The Spec's
GPU: RSX
Inputs / outputs:
Videos,
Peak power usage :
"Slowly, ever so slowly we're beginning to learn about the internal differences between Sony's new PS3 Slim and its chubby ancestry. We already knew that it supported BraviaLink while talk of "faster gaming" was introduced (suspiciously) yesterday; something that remains very much in doubt until we can confirm. Now we hear that the fatboy gone slim supports Dolby TrueHD and DTS-HD Master Audio bitstream output to your receiver. Hear that audio nerds? Bitstream. See the HDMI chip on previous generations of the PS3 didn't support bitstream output of the new(ish) high def codecs like Dolby TrueHD and DTS-HD MA. As such, the PS3 had to decode it internally before sending it over to your receiver via LPCM. A process that could garble the lossless audio depending on your setup. Even though the vast majority of people will never notice the difference (or even care), PS3 Slim owners can still kick back in smug satisfaction each time the TrueHD or DTS-HD MA indicators light-up on their receivers."
