Humming from case
6 Apr 2009
Liverpool
ok see never had this before i am getting a humming coming from my case i thought it was a hard drive so dissconnected it went a while later it appeared so i realised it wasnt that drive ..cut a long story short its my hdds that are causing the humming/vibration from the case has anyone else had this problem with the haf 932 case if so how did they sort it thanks.
is also have a 640 seagate
500 mactor
250 western dig in there as well as my 2 samsung f1s in my sig
I have the same problem as you... I too am looking for a solution.. but seems like I'm stuck with it unless I buy a new HDD to replace my 1TB Hitachi :(
Re mount it using dampening washers & reduce your sig to the accepted size.
??? whats up with the sig ?
Far too big
FAQ said:
A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post.
