Build Log: Wizard's Sleeve (FreeNAS ITX Project) :D
1 Oct 2006
"Small yet deceptively spacious" :D
Following on from a thread here about NAS options, I've decided to build myself a FreeNAS box as there isn't a NAS appliance out there that'll meet my needs.
Most of the boxes out there are either too simple, slow or too buggy and have lame vendor support for fixing the issues. The Buffalo Linkstation Live V3 was looking like the winner, until I read there were multiple issues with the Bittorrent client... that and it was missing a major piece of functionality I needed.
Buffalo's Linkstation on paper is excellent, however I think it's let down by shady software. Thecus's offerings look excellent in the all departments, however they're ridiculously expensive (£350+) once populated with decent size drives. Finally Qnap's options look good, but again their cheapest solution without drive is £180~, stick a 1TB drive in there and you're up to £250 for an appliance box.
Anyway, back to what the box needs to do:
  • Serve out a NAS share for media and backups over a LAN for 2 laptops, PC, 360 and an iPhone.
  • Act as a downloader for HTTP/FTP/Bittorrents.
  • Be secure yet accessible as it's going to be Internet facing for access to the download manager.
  • Be configurable as a web proxy server (how many NAS appliances can do this... yup, none!) as I have a mate in Spain who wants to be able to use the iPlayer and 4OD.
  • Small and quiet as per a dedicated NAS device as it's going to be in the lounge.
  • Low power usage.
Most appliances would have sufficed if it wasn't going to be used as a proxy, as the vast majority are cross platform and UPnP aware but hey where's the fun in an out-of-the-box solution? :D
So on to the fun stuff, hardware. Originally I'd been working to the budget of the Linkstation Live - £170. Despite doing much searching around, this is a bit tight but as I figured I'd be getting all the functionality I wanted and it fitted the brief I'd stretch a bit more and go for a mini-ITX setup.
  • Noah Mini-ITX case. I'm a sucker for brushed aluminium fronts, and as it's going next to an Antec Fusion HTPC case I figured it needed to look the part. Bonus with this case is it comes with an 80W PSU unit too.
  • Intel BOXD945GCLF Atom mobo with 1.6ghz CPU. Can't fault this board for the price, £60 delivered is a stonking deal. It's got 2 SATA ports which is more than enough for the above case, and an additional PCI slot should I want to expand the SATA drives at a later date. It's also got an IDE port... which I'll explain why is good in a moment.
  • Samsung Spinpoint F1 Eco - 1TB HDD. Admittedly I haven't done quite as much research into this as I should have, but having had Sammy disks in the past and knowing they're quiet I'm confident this one will be up to the task. As the LAN is the bottle neck here, I'm not fussed about the fastest performance...
  • 1GB generic DDR2-667 RAM. FreeNAS recommends a minimum of 128MB, 512MB if using RAID setups. The 1GB is overkill, but given it's only a tenner it's a bit of a no brainer.
  • 256MB IDE Flash Module. From what I've read FreeNAS recommends your OS install is completely seperate to your share drive, and in fact is designed to run from a LiveCD or a USB/Flash module. Always quite liked the idea of these modules, so perfect opportunity to give one a go.
Fingers crossed everything turns up tomorrow for a build over the weekend, will update the thread with more when it's here.
Any comments/suggestions? Experiences with FreeNAS customisation, or addition of modules and addons would be greatly appreciated.
Cheers :)
Nice one, I had originally tried to get FreeNAS working on my Atom system but I could never figure out how to get it on a flash pen :( Pathetic I know... It's currently running XP now with more or less the same specs as yours, and I have it plugged in to my stereo system so it's essentially a glorified MP3 player at the minute :D I'm not sure whether to put WHS on it and have it run backups as well, but it seems like too much effort at the minute.
Anyway, I'll create my own thread (in time) for my woes, good luck building ;)
Oh, and let me know how you get on with that IDE flash module, I'd be interested to see how well it works.
Ive setup a freenas box before, at first it might seem really complicated to configure, but i went on the basis of if you dont know what it does leave it haha
i managed to add a drive and partition it, and enable the windows networking plugin thingy
not too difficult, good luck anyway!
The guide here seems fairly straight forward, but you never know with this things until you try them. I'm not expecting my installation to be completely trouble free!
I'm hoping it's just going to show up in the installer as a standard HDD, so I just hit "Full Install to HDD" and it goes off and does the rest. Looks kinda cool though. At 256mb it's not much use for anything else bar FreeNAS or Damn Small Linux but hey.
General rule of thumb with UNIX isn't it? :)
The only thing I've got any concern about it is getting the onboard LAN working, at worst it looks like I might have to compile a driver to work on BSD but nothing major - he says...
I know nothing about setting up NAS boxes, but I just had to say that's the best name for a project I've ever seen! :D Viz rules!
PK!
Toys arrived on Friday! :D Seriously impressed with the size of the mini-itx case and board:
The IDE Flash adapter:
Another mid build:
The hardware build was silky smooth, the Noah case is a breeze to work with and save for the badly placed DC input on the back I'd say it's a nigh on perfect choice for a single drive mini-itx NAS setup.
The board itself is great, everything is in a logical place and offers the perfect amount of connections for this setup. 1 x IDE for the flash adapter, 1 x SATA for the HDD and 1 x SATA for the DVD drive for installation (machine runs without, only used for install. The only thing I can fault the board (and ultimately Intel!) is the ridiculous choice of heatsink and fan on the chipset. The CPU itself is so low powered it runs passively on the tiny low profile heatsink, but the 945/GMA950 chipset needs a bit more cooling... why they decided to do that cooling with a 40mm screamer I'll never know! The BIOS lets you drop fan speed to 50%, but it's still audible. It's been disconnected for now, and the box is silent. Temps inside the case are reasonable and the 80mm Evercool fan on the case seems to be coping nicely.
And finished, up and running with FreeNAS 0.7 installed:
Configuration via FreeNAS's web interface is intuitive and easy to follow, getting a drive formatted, mounted, shared into 4 SMB/CIFS shares and secured with users took about 10 minutes. Enabling FreeNAS's SMART HDD management, power management, email alerts and kernel tuning took about an hour or so after that. Not time consuming at all.
The Transmission Bittorrent client is fairly simple and not massively configurable, but you can set global upload/download and a couple of other critical options from the GUI. Transmission also allows for a config file which I presume allows you more control over it's functions, not looked into that as yet though. I do like the way it'll constantly scan a folder for fresh torrents and automatically download them to a folder. Coupling that with an SMB/CIFS share and a mapped network drive makes setting up and downloading a breeze. :)
Finally, the last thing I needed the box to do was to act as a web proxy for some people I know overseas who need to access the iPlayer and other location specific services for UK only folk. Installation again was a cinch, ssh in to the box, su and type:
Code:
pkg_add -r tinyproxy
Bang, done! Needed to change a couple of values in the tinyproxy.conf for interface, allowed hosts etc.. but thats yer lot.
Performance wise the little Atom CPU copes with everything I've thrown at it, it's been proxying and serving out Divx whilst syncing folders from two sources - if anything the LAN is the bottle neck. In time I'll upgrade my local LAN to Gb, but it's fine for what I'm using it for at the moment. :D
sweet is it possible to put 2x 3.5 drives in there? 1TB is too small for me. 2x 1.5TB would work better. Or maybe one of the new 2TB drives.
I don't think that case take anymore than one 3.5" drive, but I know for a fact the InWin cases take two 3.5" drives, a 2.5" drive and a slimline optical drive, possibly with room for modding a bigger HDD rack into it somewhere. My ultimate plan ;)
Awesome looking setup anyway randal, I still need to find a case fan that's close to silent so I can keep my server running 24/7 downloading and actually being useful :o
The case will only fit 1 3.5" drive slung under the mount at the back, you could fit another 2.5" where the CD drive is supposed to go though...
RJC said:
Nice setup :)
Cheers for the positive comments fellas. :)
Fan wise, that Evercool is more than quiet enough but if be aware if you were to swap the fan out for something else say a Sharkoon you might have to mod the bracket to fit it in there. The 80mm Evercool fan is about 3/4 the width of a normal off the shelf fans.
vidda said:
I couldn't find it on the freenas.org website - but does freenas support LVMs? I'd find that pretty useful.
FreeNAS 0.7 uses ZFS to combine multiple partitions into one volume, not using it myself but there's a load of info out there. :)
Do you have it running 24/7 running XP? I'm currently looking at something like this but don't really need all the NAS options.
OP - Did you get all your bits from OCUK for the build?
Really nice write up. Im think I might give this ago, do you think it could stream HD video to the PS3 ok?
Don't think you'd have any problem keeping up with that throughput with this setup. I might do some testing later on if I get some time.
Are you talking BR rips, HDTV downloads etc..?
I do indeed. It seems to be doing everything I want at the minute, purely because I can't think of anything else to do with it. I had big plans when I was living in my Uni house, but since I had so much hassle getting various parts fixed and RMA'd (4 months of hassle) by the time I got it sorted out I had moved home again... I'm thinking of just selling it but I know the instant I do I'll come up with some crazy idea that it would be perfect for. Suggestions welcome!
How much this cost you total?
Intel D945GCLF 1.6GHz Atom Mini-ITX Board Retail Box - £56.35
Silver Noah 3988 Mini-ITX Case & PCI Riser & SATA Power Cable - £67.85
256MB Disk On Module - 40 pin IDE (SMI) - £21.80
1TB Samsung EcoGreen F1 HDD - £58.89
1GB DDR2 PC2-5300 - £8.99
Delivery - £9.20
FreeNAS - Free :D
Total: £223.08
Needed a blank CD, and a CD drive to do the installation onto the HDD flash module. Oh and a KVM obviously to get it setup and on the network.
Obviously can't tell you where I got it from as it breaks the competitor rule, but it's not too hard to find those parts for those prices with a little Google-age.
The PSU is passive, external laptop-esque power brick and a PCB about the size of ten smokes. :) Silent. The fan on the chipset however... wweeeeeeeeeeeeeeeeeeeeee. Disconnected... problemo solved.
