- 13 Jan 2004
- Leicestershire
how reliable are they as i'm toying with the idea of one but i don't want astronomical running costs bar the obvious fuel issue.
didn't you post this last week?![]()
It'll never give you any trouble.
Depending how early it is, a 90s C4 will run with either an L98 smallblock or an LT1. Both are basically bulletproof but the LT1 can have issues with water in its distributor, caused by a leaking waterpump - necessitating the replacement of both. Most have been fixed with modified caps, or replacement parts so just one thing to look out for - barring the usual like making sure it's not been overheated, run dry - and has good oil pressure.
L98s can sometimes (very rarely) wear their throttle body spindles, leading to erratic idles as air leaks by. Easily fixed with a performance one though, or just a bore and re-bush.
Over 150,000 miles you ideally want to replace the timing chain. The waterpump, if it hasn't been, will need doing by then too but if it's well looked after that'll be about it. Mine had done 168,000 and was still near enough factory power and had never been touchedMany more have done lots, lots more than that....
The same applies for older ones too - but obviously age is against them in some respects, although the majority of them will have had work or replacement parts done anyway, negating the issue (or if they are lower mileage).
There isn't much to go wrong really (unless you're unlucky, then, well, tough) and they're damn fine bits of machinery.
Model? Budget?Where's the best place to buy something American? And by that I mean used. I'd love a new ZR1 but I dont have 50K!![]()
what can i do with a 2v 4.6 Ford modular engine, 99-04ish (around 200bhp stock) ?
thought maybe the 3v head or supercharger could be a long term option?
