TF2 Sniper Update
I've found out how to delete items you have more than once!!! :)
If you go into options first of all and fine which key you have assigned to "item loadout", this will then load a screen of all bonus items you've collected and allows you to delete ones that you have two of :)
Hope that helps!!!!
Hope that helps!!!!
Edit-I'll load two pictures of where I mean...2mins
Just press the 'm' key.
Just made an idle server with an idle map, that gradually kills you. So it should work.
IP: 77.99.19.18:27015
No password this time IIRC
10 slots.
Enjoy.
