Do the PSU case screw fixings line up with the case? never known any size PSU not fit an Akasa Eclipse..... The V2 Eclipse's have now extended there PSU bay to enable to fit larger power supplys, haven't seen any modifications to the case to fit the oppisite...
No, they don't. The PSU is near enough the same size as the hole on the back of the case so the fixings don't line up.
I found a pic of the V2 with what appears to be a smaller bracket installed. I'm pretty sure its what I'm missing:
No idea what I've done with it. Maybe I chucked it away cause my old psu didn't need it
Think I should contact Akasa?
EDIT (for stupidity): I just thought 'I wonder if I unscrewed the psu or did I unscrew the bracket with the psu attached?'. Checked in the box and turns out it was the latter
