Then there's also the point where moaning about the task exceeds the time taken to conduct the task itself.
A decent developer will include moan time in his estimates.
Jog on you overbearing, over-payed, hyped-up admin assistant.
 A good PM plays an important role in an organisation.[TW]Fox;14148182 said:Sounds like you are a bit bitterA good PM plays an important role in an organisation.
They do their job, I do mine, project gets done. Projects fail because PMs are incapable of managing them properly, not because devs are unable to do their tasks.
and if it is so easy and overpaid then why pray is the OP not doing it instead of sweating it as a softwear developer?
If I wanted to be despised human filth I would be![]()
As does a good developer. Why am I bitter? If I give a PM an estimate I expect them to take it and deal with it, not moan about whatever. I don't moan when a PM gives me a task, I get it done and I try to give them a reasonable estimation as to how long it will take.
If you can't estimate to this extent then may I suggest your not quite the top developer you think you are?
[TW]Fox;14148296 said:I guess thats your opinion, I'm sure on a PM forum you'll find PM's saying projects fail because devs are incapable of doing tasks properly. There are two sides to every coin.
[TW]Fox;14148304 said:Oh dear. Definite bitterness here even if you don't care to admit it. Clearly you can't see why the PM earns more money than you, so you rail against it. He is in charge, you write code, get over it.
 trust me you have it very easy[TW]Fox;14148304 said:Oh dear. Definite bitterness here even if you don't care to admit it. Clearly you can't see why the PM earns more money than you, so you rail against it. He is in charge, you write code, get over it.
Bitter about what?
It is my opinion, but since it is the PMs responsibility to deliver the project, if his devs are not up to it he can flag it to the program manager, who will reassign/replace them. I think any PM who blames his devs for failing to do his job properly clearly is not worth spit.
Bit confused what the issue is - the PM is there to facilate your work (aswell as others) so its in your best interests to make it plain to them how long x/y/z will take.
Considering you have only started on the project I can understand you were only able to guess the time needed, but I dont understand the issue that the PM has now asked you to review and confirm that guess. Hes not asking for a deadline, just an estimation of when you will deliver...
Seriously sounds like you have a chip on your shoulder and having an issue thats not really there...
ps3ud0![]()
Agreed... however I don't think it is unreasonable to expect developers to work with a PM and provide useful estimates and time-scales.. In any large development team you would expect them to be working with some methodology for work-flow planning anyway.. any team that doesn't isnt worth their spit
