I use a towel.
I use a towel.
No and surly this does not work as we have no hair which swings and then whips around shedding the water.
Oh dear. Do you sniff your sisters ass like a dog?
Someone drinking the alchy pops tonight?
I use a towel.
Soak your hand in the sink and then try and tell me flicking it doesn't remove some of the excess water.
some but the biggest pat is the torso and upper legs/arms. you are not going to be able to flick them. Unless your some sort of flexible athlete.
Just wait 30 seconds and a lot of water will just drain off.
Anyway sensible thing is use a towel you weirdos.
