Buying today...any changes?
17 May 2009
Harrow, London
I'm going to press the 'Buy' button in literally about 10 minutes. Please let me know if you would change anything? My budget is about £700 without the OS, so this is right on the borderline. Could you make it better? Please help =)
EDIT: Sorry guys, my computers just so bad, it posted by accident, without the picture being uploaded.
That looks perfect really, the only thing I would change is to get a 640gb HDD, which isn't that much more expensive.
I would...scrap Vista. Get Windows 7 RC1, and buy the OEM version when released in October. WD6401AALS drive. I'd replace all the stock fans with Xilence Red Wings or Scythe Jyuni 1200RPMs, as the stock ones aren't great...
I edited my last post about the fans. Yep, download from MS website, burn the image to a DVD using a burning app (I love ImgBurn, so easy to use), and install like any other version of Windows!
Looks good, I agree with the above though, maybe get a better hdd.
Take a look at the Western Digital Caviar Black 640GB.
Is the Windows 7 RC1 easy to download/install?
ye,s its a PC of cake. I stupidly formatted before noting down the product key but it still installed and you can update the PK. Also went from bootleg Vista ultimate 64 to Win7, will def buying a OEM when it comes out, as it seems to be more responsive and quicker.
I'd change the PSU as sugested, also that CPU cooler can block the ram slots look at the fennir.
I think the next Gigabyte board up if only a few quid more but has dual x16 PCI-E slots, much better if you plan to crossfire in the future.
Other than that looks good!
looks great. prety much my rig tbh. all id say is when i asked people said the psu might not be good enough. thats a heavy video card. they recomended this to me
http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-CS&groupid=701&catid=123&subcat=1084
also tht ram sugested is better
Meh, the power supply is going to be fine. At high loads it isn't great, but for the price, and this system, it's fine.
The Akasa fans should be okay, but people generally go for the Scythes or the Xilences.
