Pahncrd's Oblivion Enhanced Edition ( 12GB+!! )
Do we still need to change the fonts in beta 2 or just copy beta 2 over and useing the obse_loader.exe
to start the game.
EDIT= Confused now you say make sure ALL the mods a checked in the left box
but on the first page you say "10 omods in the right hand box and that they are all blue"
That torrent is pretty good. Started it 20minutes ago and its at 5% alraedy. ETA 4 hours 14 minutes :).
to start the game.
Do all those things. Not very hard actually, the boxes will be blue for sure, but because of things out of control, the mods may not be ticked. Just once you have to tick them all, not too hard.
You still need to replace the fonts section with what I put in the nfo. It is because you create your own .ini files, and the fonts need to be changed for the new in game user interface.
As a reminder, be sure not to run oblivion launcher after copying the enhanced edition over. Run oblivion mod manager first and make sure that all mods are ticked in the left box. Then you can close obmm and run the game using obse.
Neil, can you change the op to reflect this step please? I had it pop up when I installed it on my buddies rig. Other than that, it has worked beautifully on every machine I have tried it on.
Looks like I can take a lot longer on beta_03.
Newbies are a pain lol
So I ticked all on the left of the OMM and there are 10 in blue to teh right.
do I need to press the Activate button or just tick the left hand side and exit.
Sorry dude for all this I just want to get it right.
If there are all blue on the right they are the activated ones , the ones on the left are the esp make sure they are all ticked. If so you are good to go exit the manager and just run the boss.exe or bat file in data. Then run the obseloader and you are now up and running ;)
I ticked all in the left side of OMM and there wa 10 blue in the right window.
Used the obse_loader.exe to start and it started :)
But the text in some menus was off,so i edit the ini and restarted and it crashed :eek:
I did look into the font folder and found that the SFontFile_5=Data\Fonts\Handwritten.fnt
was not in that folder hmm I am reinstalling Oblivian and will try again
Its most likely it just me.
Neil acn we have a info for the beta 2 please so people wont get confused(like me I mean )
Right i've edited the nfo in my first post as i felt the nfo via the download link was not clear enough...
Hope this works out for you
Yehh all running good now in win7 :)
Everyone is so hard to beat dont remember it being that hard to kill people.
But what a Fantastic mod thank you very much.
My upload is only 250kbps sustained. If someone else has a better upload, they would be better to post the torrent.
If you can work out a way to get the file I'll try hosting it for a bit until it's seeded, have rather a fast connection here.
Oh nm, didn't read the full thread you've got it torrented now.
Get an auto installer set up for it?
Hey, sorry not bin at hoem so not got chacne to seed it. Just tryed by setting the download folder to the same one i downloaded off the newsgroup and instead it started ownloading the torrent again :/
The newgroup one isn;'t in the same format as the torrent one. Its not in rar files.
Thanks Neil great work :)
I am not looking forward to going into the Oblivion gates it will take a week to do just one lol
I think the way it works is the further out you get from the main city the harder it gets and also if an enemy looks dangerous it probably is lol. The way rpg's should be :D
