What is your system specs? have you used driver sweeper
O_O thats odd "defult clocks 750Mhz" I only get 500 :S
yeah the CPU seems a little old and yes its single core
its more than fast enough cpu wise.
have you got vsync enabled if so disable it
what settings in game
any cvars commands added in game.
Sounds like it's showing 2D clocks, what happens when you minimize a game and load up GPUZ?
should I use it for Xfire ? or something otherwise I see no point in it
it now shows the currect valueif it wasnt a dualcore id agree![]()
Are you getting just lag spikes or is the framerate taking a massive hit as well?
