- 18 Jan 2007
- Edinburgh
But have a few questions.
I have been reading about pre loaded overclocked profiles for DDR3 RAM modules and wondering what they actually are? Also if anyone knows if http://www.overclockers.co.uk/showproduct.php?prodid=MY-048-KS&groupid=701&catid=8&subcat=1389 has it.
I have also been looking at my temps of my i7 920 and the temps are as follows:
29-29-32-31
Now that's overclocked at 3ghz (i done this to see what the BLCK actually does, will get onto proper OC'ing soon) but the temps seem a bit funny, is it normal for the cores to be a good few degrees different?
I set up my 2 Samsung F1 640gb in RAID0 and i think i have done somthing stupid. I set them up as big as it would allow (1.1TB?) and set the strip size to 128 (largest setting, i think it was 128, im at work so not 100% sure).
Now I'm not sure that was ideal as I have then created a 500B partition on it using the vista install and planning on using the other 500gb partition for data. I was thinking maybe it would have been better to create a 500GB "disk" pre install and then create a separate "disk" for my data. I hope that makes sense
Also would putting my pagefile on a separate 320GB F1 be advisable or would the speed of my RAID0 be better?
Apart from all that it seems great, the case is awesome
29-29-32-31
