I keep missing the OcUK games. Just got back from hols this weekend, had a couple of games with OcUKers but not a full OcUK game. I miss them *wipes a tear*
Any other suggestions, let me know.
Link can you send me a copy of the new config later on with the changes?
Ruddles server (as you know from last night) is still a bit sketchy with the original CEVO so we need the newest on there too.
I assume I just need to plonk it in the BIN directory and just use the normal command to execture it when we are ready?
cfg directory I think![]()
I knew it was A directory...just wasn't sure so I took a stab in the dark, ok?
Alright Dad, thanks for pulling my pants down on the forum and spanking me infront of people...
I have sent you the file, run it by typing "rcon exec cevolink.cfg" without the " and away you go.
Bonsoir fellow zombie slayers. The missus is out tonight and assuming the little one gets her head down normal time I have some time on my hands tonight
Was thinking of hooking my webcam up and using the mic on that for L4D. Never used a mic in any game... ever! Is it easy enough to setup? I'm assuming (hoping) I install webcam and config mic, then go into L4D and use!
Tell me its that simple ?
Pretty much yes. Tweak the ingame sensitivity (highest doesn't equal best) after making sure that windows is set up right and your done
If your online around half 8 I'll invite you in![]()
