New Build
7 Jan 2003
Gold Coast, Australia
Just built the system in the picture below.
I have gone to install a fresh copy of windows vista ultimate 64 bit but when i get to the screen which you select where you want to install vista it says:
'Windows is unable to find a system volume that meets its criteria for installation.'
I dont know what to do am i missing something simple?
There is a load driver option.
The HDD is there it has its free and total space too.
Is there any drivers i can download to get it to work?
I have this problem on my Gigabyte EX38-DS5, I did every combination under the sun and still got the same message, in the end I had to add a partition select the new partition and windows started to load. Then find some software to remove the partition.
Pain the rear for sure, but I did not know any other way.
Its so depressing how cheap that is, back when i built my pc (feb) that would have all cost about £1400. Mine cost anout the same as yours and i got so much less =[
The bios says.
SATA RAID/AHCI Mode [Disabled]
[Disabled] Disable both RAID/AHCI function
[RAID] Enable Sata as RAID Function
[AHCI] Enable SATA as AHCI Function
Sata Port0-3 Native Mode [Disabled]
[Enabled] SATA Port0-3 Work at Native IDE Mode
[Disabled] SATA Port0-3 Work at Legacy IDE Mode
Brilliant thanks mate you have really helped!
I switched to AHCI mode and it has sorted it!
Vista is installing now do i need to change it back once Vista is installed?
Cool sounds good!
Might have to check my system in the rig to see if that setting is enabled as i never chnaged anything when i installed vista on that!
This is prooving a bit of a problem i have managed to get vista installed but when i go to run the updates the maching just hangs and everything locks up.
I have reinstalled and still the same.
Any known issues?
Could it be the wireless card?
have your tired installing windows 7, I know that it works fine, having just installed it on my cousins pc with a x58-ud3r, with that board so if it doen't instal we will know where the problem lies
The bios says.
I just managed to get it to work i set the SataPort0-3 Native Mode t [Enabled]
And it seems to be find just installing updates now.
Touch wood this will have sorted it.
