I just installed a 650w BeQuiet PSU. All was fine and dandy... until I had a very quick mess about with OCing last night.
Whacked the FSB up to 400 and left most other things on auto. Booted into windows fine, everything running ok, running prime etc.
Anyway that's not the point, the point is that the PSU had developed a high pitched squeal. if i stopped prime the squeal diminished but moving the mouse around would start it up again. Reset the settings to stock and squeal was gone. I assume its something to do with the extra volts the CPU is drawing when overclocked (1.12 ish to 1.2-3 ish from memory).
Either way, should it be doing this? is it faulty or just bedding in? Odd how it only happens when things get OCed...
Spec:
BeQuiet 650
P5Q Pro
Q9450
Corsair 4gb twinex
GTX260 216SC
Spec:
BeQuiet 650
P5Q Pro
Q9450
Corsair 4gb twinex
GTX260 216SC
