- 22 Jul 2004
Is it true that when you disable SuperFetch, it disables prefetching altogether? I've noticed that when I turn it off, startup applications take a lot longer to open when I boot my computer, and the order in which they load also appears to be different.
I've tried both stopping the SuperFetch service and changing the "HKLM / System / CurrentControlSet / Control / Session Manager / Memory Management / Prefetch Parameters / EnableSuperfetch" registry key value to 0,1,2 and 3. A value of 0 stops it churning my hard drive loading stuff into RAM, but startup apps again become slow to open. Same thing happens when I stop the Superfetch service altogether. Any other value causes the annoyance to reappear upon booting.
Does anyone know if there's a way to disable Superfetch without causing startup applications to open slowly?
