- 18 Nov 2008
Purchased
Decided to stick with vista, thanks again for all the help
MT39G-9HYXX-J3V3Q-RPXJB-RQ6D7
P72QK-2Y3B8-YDHDV-29DQB-QKWWM
MM7DF-G8XWM-J2VRG-4M3C4-GR27X
9JBBV-7Q7P7-CTDB7-KYBKG-X8HHC
KBHBX-GP9P3-KH4H4-HKJP4-9VYKQ
MVBCQ-B3VPW-CT369-VM9TB-YFGBP
C43GM-DWWV8-V6MGY-G834Y-Y8QH3
6F4BB-YCB3T-WK763-3P6YJ-BVH24
GPRG6-H3WBB-WJK6G-XX2C7-QGWQ9
This my friend is the way to go, and is cheaper than your spec.![]()
Yours is like nearly £100 more then the OP's
Don't forget to post pics when it arrives![]()
If you fancy a play with Win 7 you can run a dual boot system - just make sure that Vista is on the first partition. Below are some links and codes if you're interested.
Windows 7 RC Build 7100 x64
Filename: 7100.0.090421-1700_x64fre_client_en-us_Retail_Ultimate-GRC1CULXFRER_EN_DVD.iso
File size: 3.04 GB (3,270,828,032 bytes)
MD5 Hash: 98341AF35655137966E382C4FEAA282D
How goes the amd build? Any parts arrived yet?
Cheers Plec, I'll probably track down the thread if I run into problems with it. Don't suppose you know offhand how large a partition it needs? If it's light enough it'll get a space on a vertex.
