I have Acronis and i wouldnt put THAT much trust in it - it lost me 12gb worth of photos and videos.Well perhaps not everyone has the HD space to partition their drive
Also if you have an excellent backup solution like Acronis then you can install a completely new OS with confidence knowing you have a full disk image of your previous system on an external HD - or perhaps you are one of those people that never backup eh?
Oh and just for the record, on my main Desktop I dual boot Vista and Linux. Apology accepted by the way for referring to me as mental.
I tried the 7 beta on my laptop (Core Duo 1.66, 1.5GB RAM, crap hard drive). It ran just as well as XP. On the same machine, Vista was pretty sluggish. Both were fresh installs. That's convinced me that 7 has significant improvements on lower-spec machines.
Also, I tried 7 in a virtual machine with 512MB RAM. It actually ran pretty well. I'd like to see you try that with Vista and have anything more than a frustrating experience.
Have you switched of all power saving including the screen. Caused no ends of issues on one pc I built.
Lordy, yet I'm running Vista at the speed of light on a Inspiron 6000 with a 1.5ghz Pentium M processor 1.25 meg of RAM and just 70 gig HD. I think you need to check your setup if Vista is sluggish with that kind of setup.
I too tried W7 Beta with MS VPC on my Quad Core Desktop and it was to slow to die sudden. As I have said many times, if you are running XP then fine upgrade but if you are a Vista user then little there to justify the expense.
Finally, what are the quality of the released drivers like? NForce in particular but also the ATI graphics card drivers? Anyone having major problems?
Are there any problems at all with nVidia RAID? I've got my main drive with windows/programs and then two other drives setup as RAID 1 for important data (and then really important data is backed up offsite). I read above someone saying RAID blocks were being overwritten? Have any of you suffered data loss with raid is basically what I'm after.
I have W7 installed on my HP ML115-G5 which uses NVidia RAID. I have a main boot drive for W7 and programs, and 2 other disks in RAID 1. So far I haven't had any problems, but the machine isn't used extensively at the moment, so I can't say that one may not appear. But in reality I don't see any reason why a problem should arise.
W7beta is already > than Vista SP2 ....end of.
Havnt read the thread where can I download the lastest build please?
I had 7100 and on then installed Vista, and Win 7 blows it out of the water! lol
