2. Passcode. Before you could say, dont prompt for passcode unless inactive for x mins. Now the only option in immediate. Why give the option if theres only 1 choice!!
Pathetic isn't it? It's only for the 3Gs, even though the thing is well capable of doing it. Voice recording is 3Gs only too.Does the new version not include video recording? Or is that only on the 3G S???
Couple of things with the update that have annoyed me.
1. Cant disable push on an activesync mail box...before I could disable the push on my work email account. Now I cant...Inbox is ticked and you cant remove the tick
Am I just missing an obvious setting or something with these 2 things?
ah I meant voice commandsYou can do voice recording on the 3G - I just did it! Pathetic about the camera though![]()
Yes, I can do both on mine?
If you go to mail, fetch new data, advanced you can set it per mail account? I have all the normal options.
The standard passcode options are there for me too, i've set it to 1 hour.
See that's the thing, it is just dependant on your source. I've taken quite a few vids with cycorder and they looked decent enough. I wouldn't exactly call VGA video recording state of the art so I don't get why apple are getting uptight about it. The 2mp lens on the 3G can record and does a good job tbh.I wouldn't say it was pathetic considering that the video recording really isn't up to scratch on the 3G. Why would they want to encourage what would be a massive torrent of moaning about how bad it was? They want their products to 'just work'. The video that I have managed to get off my 3G has been frankly appalling by todays standards.
They're just trying to keep the gap between the two models as large as possible.
