Apparently the wireless controllers (ie DS3) now are controller 1 by default when you have USB accessories (like GH guitars) plugged in. Was pretty annoying before when you either had to remove your USB accessories, or change the controller config each and every time you play so that the controller is number one.
Thanks, I did try google but the wiki link i got said
and i was not sure which one applied.
The reason I asked is that I can stream from my pc without any additional software. so was curious to know what the advantage of this would be?
Who are you doing that then?
I bet you're using additional software one way or another.![]()
Windows Media Player is a built in component of Windows so you don't need additional software to stream content.![]()
I'm pretty sure you have to install it the first time you click on the icon for it, don't you?
Just because it's included with windows doesn't mean it's built in.![]()
You have to configure it, not install it. You also have to configure shared folders so i'd say they're about the same level of 'built in' as each other![]()
WMP is still a separate application from the OS, whereas folder sharing is part of it.
And WMP bites balls.
PS3 Media Server > All imo.
I didn't get on with PS3 media server, preferred tversity as it allows me to connect multiple different devices like my iphone
Horses for courses.
I run mine on my server, so I like the lightweightedness of PMS, and I only ever stream to PS3s.
I found Tversity very sluggish when my collection built up in size.![]()
Either way I don't have it installed.
Awesome - thats very useful for when I have the arcade stick in then play something else and the stupid DS3 doesnt workThe update actually has somthing FANTASTIC in it. The PS3 controller will now always default to controller 1. Those who have guitar hero, Buzz, etc will know why this is useful.
Works fine for me! Controller is now always #1!
