- 26 Jun 2009
Hi,
Ive been an ocuk customer for ages and long time lurker of the boards, but ive finaly joined as i need help.
Basicly i had a xfx 4850 xXx from OCUK and i had a problem, when it hit the mid 60C's it would crash out on me.
So they sent me a replacement.
Ive just put it in and im not getting the same problems but its acting odd.
Durring crysis war head, in rendered cut scenes im getting horizontal chopping across the screen, like if you took a screenshot, cut a horizontal line and moved the piece about 2mm to one side, and its doing this constantly durring them, and when there are flashes the strobe of the gun shots seam to go alternate top and bottom of the middle of the screen.
I ran furmark and on the stability i got to 69C and then the screen when black and i had to manual restart.
Now should it crash at all durring furmark stability or should you be able to run it untill the cows come home and close it when you wish, ran for about 3-4mins.
It does a whole bentchmarking test fine though.
It hasn't crashed durring games but ive noticed normal crysis wont start up, it gets an error but the box flashes up and goes too quick to read
Any help?
Any more tests i should do or have i been sent another duff card?!?!
Also, should i get a refund for the postage i pay to send back faulty goods?
Because if not im going to end up paying the same amount as a new card if it keeps going like this!
Any help?
