Can you get out the room?
i have
a test tube
two batteries
bar of gold (can't see what it does on the wooden panel..)
paper saying how to view the panel on the right
can't work out what to do with either panel?
Ignore the panels for now. You need to get the ky behind the breif case. ;)
i get the cube, once the uv light has batteries numbers will be written on each colour.
the keypad that relates to this doesnt work for me
I've entered all the correct numbers and it still says im doing it wrong
do you enter the code for the first colour before hitting enter?
dunno ive not got the uv light working yet!
assuming the bateries are under the chair i cant remove the floor boards
(do i need to magnetise the wrench somehow?)
also whats the sound thingy for?
You need to move the chair first to get that UV light to work...
Key behind the suit case opens the painting ( where you find a battery ) and that key opens the suit case. ;)
i also understand i have to get the AA batteries out of the beepy thing, but i swear, i can't work out how.
You select the right key and then click on the locks on the case then you deselect the key and click the handle. it opens the case.
