Can you get out the room?
I can't open the safe. I took the previous advice and I'm turning the knob on the left side where it's telling me to number 10 :(
i had 3l8r34l34r
so click the left hand side until you reach number 3. then the right side until you reach number 8. then the left side until you reach number 34. then right side until you reach number 34
Couldn't get the safe to work, whatever way I turned it or whatever I tried it wouldn't open.
Gave up. Good fun while it lasted :)
It should be XLXR etc which means turn it till the number going left, then turn it till the number going right.
Do you have the radio? If so try to open it :)
I assume you mean the thing that you play and it beeps and you can change the frequency etc.?
How? I've pressed the eject button and it just clicks, tried using all the tools on the knife and nothing :(
When you press play it makes a beep, you need to get each row to make a high pitch beep and then press the open button, and it'll open :)
I cannot get the safe to open.
My code is 16R 40L 6R 5L have moved to the numbers in the right direction, do I have to click somewhere when I have gone to the number?
