tis true, i ordered one earlier today for about 32 quid and there were 7 left in that listing alone...It's not Wonderlandstores.
It's Wonderonlinestores.
you will have no problems
what are these guys made of since it doesn't matter for them to get wet?Ah one of mine (my flickr being djcopeman).
ahh coolSome sort of plastic which has been painted.
- do you have the little one of the big one greywolf? your pictures are awesome
Yeah mine did this. Just pull the leg off and then rotate the joint until its where you want the leg to point. Sometimes its pretty stiff so you may need to use pliers.
ahh cool- do you have the little one of the big one greywolf? your pictures are awesome
Just pull the leg till it comes off? Do all the joints do this? Even the head? (wondering about replacement of batteries)
MM thinking of getting one of these but which one...
There seems to be a few different ones, search for ダンボー to see the variants .
I like this one:
and nowhere near as photogenic imo...Thats several Danbos fitted together![]()
thats class !!!!! what was used for the green light ?? i take it that you used your new remote switch ?
I took it a little while ago, during the 5+secs theme, forgot i shot it
This was with my infared remote. The light is a mini green/blue mini light saber, it was a free gift with an order i put in on dealextreme
Just seen that you dont have the port required on your D60![]()
