Can you get out the room?
You need batteries for the light & think algebra! When the time arised you will see what the number is for.
Right this is now jsut ******* me off now.
On the bit of paper i have
1.c1
2.a2
3.c2
4.d1
GO=B1
OD=A3
LU=B4
CK=A2 not d1
k after your email!
you said ck= d1, its actually a2, check out the last piccie you sent me!
soooo given that here are your 8 numbers
C1, A2, C2, D1, B3 (GD), B2 (LK), A1(OC), A4(OU)
Me. I'm currently doing Lights.
Trying to break out of my first room without a walkthrough / hints.
I'm not confident.
Stuck on the the [Vision] room again :o
I have the weird box that you look into, and i assume the code goes into the 4 digit lock, however I can't get it to open?
Clues for the number combination on the bottom cupboard draw ( key = triangle + square X circle (or whatever it is)):
BODMAS (or BIDMAS depending on how you were taught it!:D )
If you still can't figure what it means, google it.
