- 13 Jan 2004
- South East
Cant be that good if it blocks your sweat pours?
That's the point!
That's the point!![]()
If you work out more (jog, play a sport or work out generally) then surely the excess sweat is filtered out naturally this way so in an everyday normal situation you would not be sweating?
Obviously thats the point, but blocking sweat pours isn't good, i certainly wouldn't be doing it all the time,
was a bit harsh. Blocking some sweat pours really is no issue though. You just sweat it out elsewhere, and evenly so you don't even notice it.May I suggest losing some weight before resorting to this.![]()
You need to work out to lose weight![]()
So I used that Driclor stuff for the fist time last night before going to bed. Holy great mother of god! I ended up wanting to stab my armpits with tweezers 5mins afterwards!
The stuff is amazing, and really does work well but - It hurts, it hurts!![]()
Actually Squirrel, you don't. Blocked pours won't stop the glands producing sweat. I.e. you'll get spots.
Exercise should only be used as a last resort if surgery doesn't work.
This product sounds like hell
I can't get on with ANY Anti-Perspirant that contains the Aluminium (I've only ever tried ones containing this.. as its the only way to stop sweat IIRC)
If makes my armpits feel clogged up and generally uncomfortable, then when I go for a shower the soap feels like its having no effect on removing the anti-perp and leaves me with an unclean uncomfortable feeling.
I just use regular Lynx now..
