Well, I gave it a go. But the enemy decided to send ALL the tanks after me, it got messy.
Cheers mate, must be doing something wrong as I just done all that even the HT thing and only getting around 30 fpsFirst thing that stands out is your viewdistance is 10000 (10km) and AA is High, both will have quite a big effect. Try setting AA to low/normal and viewdistance to 2500 (as most mp games limit this to around 2000 anyway).
To answer your other questions:
Vsync option is in the ATi control panel, but if you're running vista or win 7 you'll need ati traytools to disable it - go to Game Profiles > Manage Profiles. Create one if you dont have a default one already, the disable vsync - vista workaround option is in the Direct3D Tweaks tab.
Disabling HT will not affect your overclock at all. Pretty much all games benefit from having HT disabled btw
As for the config file being changed back every time, just right click the file, select properties and tick read only, that'll stop it!
wow i diddnt know that. all i know about HT is that it generates more heat when its enabled.First thing that stands out is your viewdistance is 10000 (10km) and AA is High, both will have quite a big effect. Try setting AA to low/normal and viewdistance to 2500 (as most mp games limit this to around 2000 anyway).
I applied the latest patch and now I get a securerom error sayings wrong disk inserted ...
I have the steam version btw.
great so now what?!
Edit: Is there anyway to reinstall from steam without re-downloading?
Edit 2: oh well here I go again with another 12 hour download ...
and thsi shall be the very reason i shall never buy digital download content!
me loves my discs <3
As sarcasm said, #vote kick playernameCould really do with an Admin at the moment. Got an idiot treating MHQs as his personal transport and TKing anyone who tells him to stop.
Oi blackvault, can you send me your excel sheet mate via msn later tonite when i get home ? just wanna make a lil change and see what yoou think
Sarc
