Have you a link to that wallpaper?
What dock is that?
Getting a License Key and Partner Id from weather.com
Weather.com requires that you sign up with them to use this service. Once you sign up at: http://www.weather.com/services/xmloap.html, you will get an SDK that explains the XML data format that they use and the HTTP GET query string/URI that they use. They will also give you PNG files that are icons for the different weather conditions that are reported. They also require that you use the License Key and Partner Id that they give you to make HTTP GET calls to their service.
Yes.is that something that shows current song playing in bottom left?
Here is my main monitor at the mo:
	The window skin? Ummm, Royal Noir i think. (at work atm)
I dont use it anymore.
Mine looks like this now...
http://forums.overclockers.co.uk/showpost.php?p=14186281&postcount=10646
how do you set all that info up on the right of your desktop? Looks cool? Can you edit the font too?
Awesome mines been working on and off for a while now, been wondering what it was just haven't bothered to try and find out. lolJust a heads up - if anyone's rainmeter weather feature uses weather.com is now suddenly not working, I think weather.com changed the authentication of their XML service, and you need to get a partner ID and license key to make it work.
from http://developerlife.com/tutorials/?p=18
I just got mine working by signing up, was emailed the key and ID immediately.
SimonC is correct, for the time and weather, the sys info is the default 'tranqull' theme i modded. More details in the link below the image you quoted.how do you set all that info up on the right of your desktop? Looks cool? Can you edit the font too?
my desktop 2560x1600
Cheers for heads up.
SimonC is correct, for the time and weather, the sys info is the default 'tranqull' theme i modded. More details in the link below the image you quoted.![]()
http://rapidshare.com/files/253860612/Danbo.zip.htmlCould you link the desktop to the one you've got in your post there?
