I don't think the waiting times will be as long now, think he was having to get a few things ironed out.
 Damage past the front wing is pretty much non existent, and thanks to free labour from good (skilled) friends and a bit of luck with cheap parts, it'll be back
No i bought them off a guy on the nutz forum as he got them from 949 racing and never fitted them before he sold his car, just luck really.
How long did it take you to fit all the bushes or did you just fit the rears? I wanted to do it and for £25 i couldn't say no.
They are very very easy to fit, I have fitted the full set minus the two clamp bushes for the front ARB (will get round to it at some point).
It probably took me around 1.5 hours for the front and 1.5 hours for the back, but I tend to take my time with these things.
How will you be getting the old bushes out of the drop links? I have a big vice bolted to a metal table which I used - I imagine you would struggle greatly with anything less than a big vice or a press. The rubber of the bushes will be bonded to the metal body of the drop link, it took me very little time to force the bush out but I was still left with small amounts of rubber attached to the drop link which i scraped out with a little screw driver.
I remembered there was some talk of the P5 sportdrive in this thread so I thought I'd share what I have.
Dont know whos interested but i had my sportdrive kit fitted at P5 last week (I was the first to have it fitted apparently) I also had the alignment done at WIM afterwards
I'm very pleased so far. It makes the most difference in high speed cornering particularly over bumps mid corner. its just so planted and body roll is cut significantly. I recon grip has increased at least 20%. low speed bumps are harsher than the standard setup but thats to be expected with 100% stiffer spring rates I guess. the ride is still good for a sports car.
hope all those who are getting the setup enjoy it too.
Pete
Pete
I wont post any pics
however to answer Dorje's q's Fast bumpy b road handling is very good as it handles fast bumps very well. It just feels very composed on the bumps which in turn makes you feel absolutely planted.
it lowered my 97 mk1 by 2-3cm (330 F 345 R) which looks nice but not slammed. Phil doesn't recomend going much lower (just need better wheels now)
I'll leave the rest to howard, as I feel that I might be spoiling his big moment....![]()
 The characteristics you mentioned in your first paragraph are exactly what I'm after
Your opinion is very much valued, I'm glad I haven't bought into a crap product..The characteristics you mentioned in your first paragraph are exactly what I'm after
edit: Whose alignment settings did you use? WIM's 'fast road' setup, or Phil's?
