- 18 Mar 2009
- Indiana, United States.
All this talk of crashing makes me not want to install it. I have both 7100 and 7232, and now I'm thinking about this 7264. Which is the best?
Beta/RC keys don't work!
http://tweaks.com/articles/39088/extend-activation-period-to-180-days/ :
Would you like to extend the activation period to the maximum 120 days instead of the 30 day period that is set by default? It is possible and legal to do this using the software licensing manager in Windows Vista and Windows 7. Simply run slmgr -rearm to get another 30 days at an administrative level command prompt. You can do this a maximum of three times before Microsoft blocks further extensions.
Right, just put everything onto the external HDD, got a spare 500gb HDD from work, going to Raid0 it and install 7232.
Wish me luck!
Good luck and let us know how it works out for you.
All done in about 15 minutes, awesome!
Got a blue screen after plugging 2nd HDD in for the first time, missed the Ctrl+I for Raid setup. ><
Task bar is a bit random! As is notification area.
Good stuff, going to install some games now.
I tella lie, had one more problem that i was devastated about.....ultramon doesn't work!!!!Using displayfusion in the meantime which is alright until the get UM fixed.
Just got this build today:
will Windows 7 x64 work?![]()
No it won't work with new hardware.
Installed 7100 today and so far very impressed. definitely running much lighter than vista was. Had no issues with apps or hardware so far with the exception of my old creative SB Live!42 external. The beta win7 drivers are a bit rubbish.
lol!
It will be fine chrisxuk
