Hey. Just a short question here.
I believe the i7 920 has a maximum multipliar of 20, so 4ghz requires a bsck of 200. However there is something called turbo which I haven't met before, am I correct in that it adds 1 to the multi when only one core is under heavy use?
So 191 x (20+1) under turbo is also 4ghz.
If the above is correct, then I am confused. If when under heavy load it drops to x20, then the chip is then running below 4ghz.
Would 200x20 without turbo not be far better than 191x21?
