OK I got the UPS working. I just needed to turn it off and leave it off from the wall for 30 mins. Then Hold in the test button for 10 seconds to reset it.
Installed the addin Grid Junction
All is good now.
Now for the BIG question.
I copied some MUSIC and VIDEOS over to the server via USB external drive.
I logged on using remote desktop and copied direct from USB drive to
D:\shares\Music
D:\shares\Videos
Now having read up on it people have said this is not the correct way and it should be avoided.While others have said that they have done this without issue's.
How do I know if everything is OK?
Apparantly someone said to check:
"Since you copied directly to the D:\shares\Sharename folders, you were operating outside of WHS. The risk you run is that you may create real files in the shares, rather than tombstones. In this case Drive Extender won’t be able to move those files off of the primary data partition.
All files that are located within D:\shares\Sharename should be 4KB tombstones only, no matter how big the real file is. The actual files are located on other drives that WHS accesses through mount points that are in C:\DE\ (in a single drive system the files are stored directly on the D drive).
To make sure that the files in D:\shares\Sharename are tombstones only, right click on a file, then Properties and look at the Size on disk. If the Size on disk value is more than 4KB then the DE Migrator is not coming along and migrating the actual file to the other drives, and is not creating the tombstone.
So the only way I can see that you can rectify this is to take the incorrect data out of the shares from D:\shares\Sharename into a temp directory and then move it through to the actual share the proper way."
Well I have checked and none of the files are 4KB in size when I look in my D:\shares\Videos folder for example.
Is this pre landing Zone stuff? I know that this was scrapped in PP1.
Should I be worried?
Everything seems to be running okand balancing well. I have oodles of space on my SYS drive left.
Could anyone check the file size in the D:\shares\Sharename areas please?
I want to get this right and its all so damn confusing.
If push comes to shove then I suppose I can copy the data from the unc paths shares to USB drive again.Delete all the data in the shares and in D:\shares\Sharename and copy back directly through the UNC path...
Please help I'm a WHS noob
