ok its starts with me buying a pre overclocked bundle from OCUK see my specs... well when i recieved this bundle and tested for stability using Intel Burn Test and was shocked to see that it failed in the second pass...
OCUK overclock settings were
BLCK 200
QPI Link Speed (AUTO) X36 (at 7.2ghz)
Memory at 8X 1600mhz
(memory timings 9-9-9-28 Command Rate (CMD) 2...)
Unicore Frequency (AUTO) (3.8ghz)
Vcore Voltage 1.3000Volts
QPI/VTT (AUTO)
DRAM Voltage at 1.64V
so being farmiliar with overclocking (not near as good as some people on here)... i thought it might be becasaue OCUK have set most of the setting to auto so i changed them to see if i can do better....
attempt 1
BLCK 200
QPI Link Speed X36 (at 7.2ghz)
(memory timings 8-8-8-24 as stated with the memory i got, CMD 1)
Uncore Frequency 16X at 3200mhz
QPI/VTT 1.33volts
DRAM Voltage 1.64 Volts
UNSTABLE in Intel Burn Test failed within first 2 passes (BSOD and random restarts)
(BOLD THE OPTIONS I CHANGED)
Attempt 2
BLCK 200
QPI/VTT 1.33volts
DRAM Voltage 1.66 Volts
Attempt 3
BLCK 200
(memory timings 9-9-9-28, CMD 2)
QPI/VTT 1.33volts
Attempt 4
BLCK 200
(memory timings 8-8-8-24, CMD 2)
Uncore Frequency AUTO
QPI/VTT 1.33volts
Attempt 5
(memory timings 8-8-8-24 as stated with the memory i got, CMD 2)
Uncore Frequency (Auto)
QPI/VTT (Auto)
Attept 6 (my ONLY stable settings)
so i started to ponder that the problem might be with the memory... so i attempted these settings
BLCK 200
QPI Link Speed X36 (7.2ghz)
Memory 6X 1200mhz
(memory timings 9-9-9-28 CMD 2)
Uncore Frequency X13 2.6ghz
Vcore 1.3000volts
QPI/VTT 1.33 Volts
DRAM voltage AUTO
lo and behold everything running stable however if i move the memory up to 1600mhz with any of the above settings (apart from attempt 6) it becomes unstable... i can say after all this testing and pulling out several handfulls of hair that the memory is unstable because attept 6 shows no different settings for the cpu only diff is that memory is downclocked... guarantee the memory is faulty or els i shoot my self in the knee caps....
any suggestions info help or anything im missing doing wrong would be a appreciated.... thankyou
if the memory is faulty what do i do??? RMA it back to OCUK??? also would i need to only send my memory or the whole mobo and CPU???? im sure its deffo memory...
BLCK 200
QPI/VTT (AUTO)
attempt 1
BLCK 200
QPI/VTT 1.33volts
Attempt 2
BLCK 200
QPI/VTT 1.33volts
Attempt 3
BLCK 200
QPI/VTT 1.33volts
Attempt 4
BLCK 200
QPI/VTT 1.33volts
Attempt 5
QPI/VTT (Auto)
BLCK 200
Memory 6X 1200mhz
Vcore 1.3000volts
QPI/VTT 1.33 Volts
DRAM voltage AUTO
