*** MM7 Offical thread ***
Thats what caused the power loss? I popped an intercooler hose off whilst doing a shakedown run after fitting FMIC. It wouldnt even rev past 2K. Let go with an impressive pop though. On another note mondeo is with the mechanic only time will tell to see if i get it back in time.
im not entirely sure to be honest.
I had an incident whereby it wouldnt rev past 2k, but then turned the engine off in a panic, and turned it back on again and it was fine.
It had intermittent hicups and lights for a week or so before finally comming off alltogether and not starting.
lulz. I'm pretty sure I've called him Si many times on this forum before, but noticed someone called him matty :/
Si, call me Dave if you want:p
edit: Dup you mongy homo:(
Bit out of the way for me ;) Wetherby Services is easiest as I'm just north of the Dishford Interchange :)
