He has a point here. It takes me weeks to get my PC to how I like it after a fresh install. Just Windows updates, Office 2007 and updates, and Visual Studio 2008 plus updates takes an evening.
Might aswell go with Windows 7 as it is cheap at the mo and a very good OS.
And what were they thinking with the lack of quick lauch? Yes I enabled it, but to have it disabled by default is daft.
It would be bizarre if you installed it, and DIDN'T want to upgrade.
I can't understand how people would put up with a setup that takes days/weeks to reinstall. It's not so bad with Vista, but back with XP after a few months it ran like a dog, cue the reinstall. Maybe I have some Windows OCD, but as a result a simple batch file to backup and restore key user data and settings, a base install image (sans drivers), a partitioned drive with the bulk of applications and data on separate partitions, and I can be back up and running in 20 minutes, an hour tops for everything just as I like it.I can't come round to understanding how it takes days/weeks to return to a similar state of an OS post fresh install!
It's just my own uncorroborated opinion, but I think the reasoning behind MS's decision to release/leak the betas and then the RC was never primarily to do with "testing" as such, more a (very successful) exercise in viral marketing, although I'm sure they also got some useful feedback as a byproduct.I'm not quite sure why people want to "upgrade" from an operating system that is in it's release candidate state to the release code.
I think some peoples minds have slightly drifted with regards to the whole "testing" aspect of Windows 7.
It's just my own uncorroborated opinion, but I think the reasoning behind MS's decision to release/leak the betas and then the RC was never primarily to do with "testing" as such, more a (very successful) exercise in viral marketing, although I'm sure they also got some useful feedback as a byproduct.![]()
So do it once, then make an image? As long as your hardware hasn't changed in the interim, all that you'll have to add are any updates since the image was created.
There's simply no point. I've had to reinstall Vista twice since Nov 2006, all due to hardware failure. The time it takes me to image and then run all the updates is almost as long as it would take me to reinstall when you average it out over the years.
Fair enough. If you aren't so unlucky though then it's a sound approach.
